Delaware Valley S2000 Members Delaware, Eastern PA (Philly)Southern New Jersey
14.83's at the track any advice?
Old 04-25-2008, 07:40 PM
ronnycage's Avatar
Default 14.83's at the track any advice?
my launch I keep falling on my face on. my reaction times are not horrible but shortly after i just crumble.
60-2.396
1/8-9.761 76mph
1/4- 14.831 96.86
im launching about 3k-3500. I shift at about 8k and I think im loosing everything in my launch. I keep sputtering and chugging. any advice at all?
thanks del val crew!
Old 04-25-2008, 08:14 PM
pepperinyoureye's Avatar
launching that low i seemed to bog,deff try and launch a little higher..are you on the stock clutch?
Old 04-25-2008, 08:30 PM
2poor2mod's Avatar
you need to launch about 2-2.5 RPMS higher, you are doing more damage to your diff at those low rpm launches. launch higher with slight wheel spin and you should be ok
Spec_Ops2087's Avatar
Launch at 5.5-6k rpms and floor it. It'll spin and should hook up around 8k rpms, then shift into second and your golden; thats how a managed a 1.9 60' on SO2s with a stock s2k
Old 04-26-2008, 10:01 AM
wills2k106's Avatar
Definitely need to launch higher around 6000, less if the track isn't so good, more if it is stickier. You need wheelspin with every drag car, but it is vital in the S2000 because it doesn't make enough torque to recover.
Old 04-26-2008, 10:43 AM
Mr. Francesco's Avatar
Forget drag racing and start auto x'ing and tracking
s2000 isn't made to hit anything better than 13.9's out of the box.
You need to launch right above the vtec point so that once you start going the revs won't fall to low to where it takes time to get back into vtec. Also, you have to redline every single shift. Don't shift at 9k, shit after 9k when the light comes on.
Old 04-26-2008, 12:22 PM
s2000isu's Avatar
You should be shifting at 9k. As said before if youre bogging off the line rev it up more when you launch. What track do you race at?
Old 04-26-2008, 12:24 PM
probably atco.
Old 04-26-2008, 12:46 PM
Zippy's Avatar
What he said, this is a car that goes around corner much better than 1/4 mile.
Old 04-26-2008, 04:05 PM
ronnycage's Avatar
I actually have a BIGGER interest in the cone course I have competed several times... im actually competing tommorow!!!
ok def launching higher up in the 6k to 7k range now then.
thanks guys... any tire psi reco's???
i raced at atco twice now 14.8's both times... I just want to keep beating my buddys crx si with a b16 thats running a higher 14.8 then me... we've grown up together and its been nothing but fun racing him.
see whoever is doing auto x tommorow at the CCC course!!!
Quick Reply: 14.83's at the track any advice?
