tl brembo calipers on s2000?
Old 03-16-2012 | 02:45 PM
yellow94eg6's Avatar
Default tl brembo calipers on s2000?
wuz up s2k ppl i was wondering if anyone here knows of a way to put tl brembo set up on a 04 s2000. i picked this set up today and want to know if any1 know how to make it work before i just give up on it and sell the set up
Old 03-16-2012 | 03:59 PM
phaeton's Avatar
I'm afraid I can't be of much help here other than to point out that the S2000s stock brakes with any halfway decent brake pad are more than enough to lock up the tires when coming to an abrupt stop, so at least in stock form, the only way to really achieve better braking by any significant margin is through wider tires or a stickier compound. You could argue that they are less likely to overheat when used heavily i.e. hot laps on a track, but even that is stretching it.
Basically, even if it's possible I'm not sure it would be worth the trouble unless you spend a lot of time on the track.
That said, here's a post I found on 8th Civic where a guy says his friend is running the same calipers on S2000 rotors, so it would seem that it's a distinct possibility.
http://www.8thcivic.com/forums/suspe...ap-08-fg2.html
Old 03-16-2012 | 05:54 PM
homesivan's Avatar
If it work I would love to do it on mine I bet it will look great .... I know the 06 accord v6 6 speed calipers will work
Old 03-17-2012 | 05:34 AM
thanks guy. yeah on the 8th gen civic they pretty much bolt on all u have to do is drill the spindles to work with the 14mm tl bolts or insert threats to work with the civic 12mm bolts. am going to try and see what it would take to fit this on there this week.
Old 03-17-2012 | 07:33 PM
Boricua's Avatar
Agree,
I think they will fit fine, I saw the DIY accord calipers and they look very good.
Perhaps the TL calipers will look way better and unique!!!
Please do a DIY with pics if you decide to do it, I will love to have it done as well, thanks!
Old 03-20-2012 | 03:53 PM
homesivan's Avatar
Any luck
Old 03-20-2012 | 07:19 PM
none this sucks. lol i think im just going to by a kit
Greg W
10-23-2010 03:06 AM
az3ar
11-09-2009 12:28 PM
Gloffer
03-20-2009 11:13 AM
ADiSKOTEC
09-11-2007 01:54 PM
yipee
05-31-2003 08:48 AM
Quick Reply: tl brembo calipers on s2000?
