test pipe
You can run a test pipe, or high flow cat on any car without a cel light. Go to advance auto and buy a pack of 18 mm spark plug antifoulers. Screw the two fittings together and drill the outer out to one half inch. Screw the fitting into the 02 port on your test pipe and install the sensor into the drilled out fitting. I have been running this on my 06 forever. NO cel light. The fittings cost 4 dollars and take about 3 minutes to install.
![light.gif](https://www.s2ki.com/forums/images/smilies/light.gif)
cookies28
07-11-2010 09:53 PM
