Reputable shop for AP1 tranny work
I've got an '00 with 31k on it and the 2nd gear grind recall work was done on the car at 5k miles. It recently developed a grind going into 1st while moving. If I bring to a stop, shift into second, then into 1st, it goes smooth.
Looking for a shop that is hopefully familiar with S2000's to see what they can do with this.
It started doing the grind and I took it in to Honda to see if new fluid would help. Service did not change it. I don't think clutch fluid could do this, could it? I'm pretty sure it's not dirty. I sucked some out with a turkey baster and added new fluid as recommended by Billman in a post somewhere.
Clutch fluid could only cause a grind if the level was low and the clutch wasn't completely disengaging. If it's only grinding in to 1st, probably not clutch related.
Sorry to disagree. I would check the clutch fluid before taking it to a shop. I've had problems with grinding before when the clutch fluid was low or trapped air (basically, the clutch is not disengaging fully, so you're rev matching 2-1 now (cannot rev match from a stop)). You can top off the clutch with brake fluid and bleed the system like brakes. I'm sure there is a how-to write up somewhere in here. Bleeding the system very inexpensive compared to transmission work. Eliminate the least expensive culprits first.
https://www.s2ki.com/...-trans-rebuild/
Here's the problem with trans work on the S, 1) you have to drop the trans, 2) parts are gonna cost you ~$200, 3) labor is gonna be $$.
Buy a known good trans and swap it in. Do the clutch while you're in there too.
Personally. with a car and that low mileage, I'd beat the piss out of it on a track, there's a damn good chance it'll fix your issue. If not, you'll have had a blast anyway.
The grind started the day after driving the car at 135-140mph for 10 miles.
I'm also pretty sure clutch fluid is at correct level and clean. The car has been driven rather easily minus 2 moderate track days and obviously the 10 mile run.
Keep us updated - I'm interested. It sounds as if they clutch isn't fully disengaging.
