rear camber
rear camber
ok so i have a +35 offset in the rear of my s. i love the way the wheel looks, all deep dished and what-not. so i had to put aluminium spacers in the springs to stop the sidewalls from rubbing on the fenders. i had yellow jacket roll my fenders and that pretty much solved the rubbing problem, it also got rid of the horrible lookin fender gap. now it only rubs when i hit a good sized dip in the road or an uneven patch on the interstate. now that they're rolled the tires are rubbin on straight fender and i dont wanna start eating the paint.
i've searched the site and all i can get is people saying that a -1.7 camber is about the max i would wanna go or i would risk eating the inside of my tires. while others say they are runing -2.0 and are having no problems... im super confused. i just wanna know if any of you guys can shed any light on my dilema.
heres a pic of the current set up
thanks,
eric
thanks,
eric
I think -1.7 degrees is barely within the factory alignment specs (or barely outside it). You won't go through tires much faster at all going to -2 camber. Tires start to show inner wear at about the -2.5 mark and up.
But if I were you, I would run whatever camber I needed to stop that rubbing. Tires are cheaper than replacing fenders!
This is my set-up if it helps you any
Front:
17x8 43et 215/45/17 an -2.0 camber
Height:
from edge of fender to lip of rim 3in.
Rear:
17x9 43et 245/40/17 an -3.0 camber
Height:
From edge of fender to lip of rim 3 1/4in.
And a D.I.Y. fender roll
Front:
Height:
Rear:
Height:
im at i think -2.5 on the rears. tires have worn some but then again i drive like an a****** 95% of the time. just have the rear tires swapped at like 10k miles and i think you should be fine.
Originally Posted by Dressed2Kill,Jun 1 2009, 12:18 PM
I run 3.25 in the rear and around 2.10 up front. I get my tires fliped side to side to get twice the life out of them.
Originally Posted by RichV,Jun 1 2009, 12:31 PM
You can't do that with directional tires though right? I know all three sets of tires I have had are directional.
