Ran into another issue
Old 01-16-2012, 06:20 PM
SgtB's Avatar
You're going to need a stupid long breaker bar, a longer pipe to go over it and a lot off ass and swearing to break the bolt. Don't use heat or anything like that, just use a snapping motion. You will need the honda pulley wrench which is basically a big nut with a handle on it to hold the pulley while you pull. A pulley remover is needed to remove the pulley from the crank. That's about it. Searching vortech sc posts on here should give you an idea as they have to swap pulleys.
Banned
wadzii's Avatar
just take off the accessory belt and the 19mm bolt that holds the pulley on. The bolt is usually pretty tough to get off, but if it has been removed before it shouldnt be too bad.
Old 01-16-2012, 07:02 PM
ArchAngel2K's Avatar
Is it a reverse thread or regular? How hard is the pulley to get off
Redef90
05-10-2016 06:57 PM
s2cho
22
05-23-2013 08:30 PM
aerowilson182
02-10-2007 08:06 PM
flexer
04-03-2006 05:30 AM
ATXS2K
07-27-2004 02:30 AM
Quick Reply: Ran into another issue
