Ran into another issue
Yeah so i ran into another issue besides my obsession with strip clubs EPIC NIGHT!!
anyway my front Seal on the timing chain cover behind the harmonic balancer leaks quite a bit i have noticed. has anybody else had this problem when running FI?? and is it easy to fix? its the small $h!t that causes the biggest problems so i need to get this problem fixed STAT!! Ideas, thoughts
Thanks
Blake
Thanks
Blake
1 Post
im relatively sure they had some info on this under the "blow by and venting" thread. Something about not using the PCV stuff anymore and running open vents into a catch tank. Alloy craft sells one for the boosted crowd last i saw. You may have to tap larger holes into your valve cover if you are running alot of boost. (I am by no means an expert, just done my research a bit)
I agree. Sounds like crankcase pressure. If you're running the stock breather hose to the intake arm you shouldn't have enough to blow seals though. A catch can may solve the problem, although that seal may be toast by now. Is your compression good? You may want to upgrade to a supra pcv valve if you're running one.
Banned
If there is enough pressure to push oil out of the front main seal then you are getting some crazy blow-by. I'd start w a compression test if that's ok then replace the pcv
You can always clean out the one you have. Soak it in some Carb cleaner
I think the problem started when my timing chain snapped one day and this shop replaced it and all the seals so I'm pretty sure they dicked it up
