Civic DIY question. Looking for some expert help.
Looking to crowd source a Honda Civic question.
I replace the SRS module on a 2006 Civic because of an internal fault error that, apparently, cannot be cleared. After installing the new/used module (exact same part number), I’m left with an 81-64 code “ECU Serial ID Code Inconsistent Front Passenger's Weight Sensor Unit”.
As a DIY person, I’d like to fix it myself but I’m not sure I have the equipment to do so. Everything I read seems to require a Honda Diagnostic Computer.
Is there a way to reset this myself or, is there someone who isn’t a dealership in the Charlotte area that can “fix” it?
Thank you in advance.
Airbags (SRS)
Supplemental Restraint System
SRS - Supplemental Restraint System
81-64 PERMANENT
Airbags (SRS)
81-64 PERMANENT
