Powerflex bush replacement
Ridiculously hard...but worthwhile, it's nice to know they'll never seize (if you grease the bolts like Honda failed to) I've done the rears on my S, with a view to renewing the fronts this month.
Powerflex ones are brilliant because they come in three parts, negating the need for a press to get them in the wishbone.
I have no doubt it's just as difficult on other cars...are you thinking of doing it on your BMW Gad?
powerflex bushes themselves - easy to change. it's actually getting the parts off, and old bushes out that make 'powerflexing' difficult imo.
worthwhile - noticed no handling differences, but happy to know they were the fraction of the price of honda bushes and will last practically indefinately. only had the 2 rear camber bushes done on the S.
I've done it on my S2000 DIY and it was a right PITA.
TBH the only reason i did it was because a) The bushes had seized thus geo out, b) You can't buy the bushes seperately off honda.
Banned
there are six bushes involved iirc
I can see how it would be easy to do the two at the rear
I need to look at the four front bushes
I am good at taking things apart - so that won't be a serious problem
I am less good at putting things back together - so that needs to be simple
With Powerflex bushes the putting together is the easy bit.
The problem for you will be getting the old bushes out. Expect bleeding hands and a lot of swearing, followed by inappropriate use of one or more of the following;
Blowtorch, chisel, big hammer, bigger hammer, rock.
Banned
I reckon it will take me no more than two hours........for the whole job
I know i can do the two back ones in under 30 minutes, so it's the fronts I need to check out
I have all of the implements you describe......plus a few others, so I should be ok
Originally Posted by loftust,Sep 3 2009, 08:57 AM
Ridiculously hard.
Whilst it will probably sharpen everything up and they won't wear out, isn't there a trade off in that you'll lose some of the damping of the standard bushes and transmit the forces elsewhere?
