Z06 move over...911 twin turbo move over...
Superperformance uses another car "hacked up" as well,
The only parts of a Mustang 5.0 in the FF Coupe is the engine, wiring harness and possibly tranny,
ENGINE / DRIVETRAIN
CLUTCH CABLE 1
ENGINE, 5.0L FORD
BELLHOUSING W/ MOUNT BOLTS
T-5 TRANSMISSION, W/ MOUNT BOLTS
TRANSMISSION MOUNT W/ MOUNT BOLTS
DRIVESHAFT AND 4 ORIGINAL BOLTS
REAR AXLE ASSEMBLY, COMPLETE 1
SPEEDOMETER CABLE
CIRCLIP, CLUTCH CABLE RETAINER
ENGINE MOUNTS, CLEAN STRAIGHT, W/ OEM NUTS
MASS AIR SENSOR 1
EXHAUST
OXYGEN SENSORS
RUBBER BUSHING, REAR EXHAUST HANGER
FUEL SYSTEM
FUEL TANK W/FILLER NECK, CAP AND MOUNT STRAPS 1
FUEL FILTER W/BRACKET AND HOSES
HIGH PRESSURE FUEL LINE, W/FITTING, ENGINE BAY, CUT 4" INTO STEEL LINE
LOW PRESSURE FUEL LINE, W/FITTING, ENGINE BAY, CUT 4" INTO STEEL LINE
FUEL EVAPORATIVE CANISTER, SOLENOID AND TUBING
EMERGENCY INERTIA CUT-OFF SWITCH
BRAKES / WHEELS
BRAKE CALIPERS, FRONT, CUT 4" INTO STEEL LINES
BRAKE BOOSTER, DISTRIBUTION BLOCK, CONNECTION LINES 1
MOUNT, FRONT, FLEXIBLE HOSE TO STEEL LINE, MOUNTED TO BODY
EMERGENCY BRAKE HANDLE, W/ "T" CABLE AND HARDWARE
WHEELS 4
SUSPENSION
REAR QUAD SHOCKS W/ MOUNTS AND OEM NUTS/BOLTS
FRONT SPINDLE BOLTS
SPINDLES, FRONT 2
CONTROL ARMS, REAR UPPER W/ BOLTS/NUTS 2
CONTROL ARMS, REAR LOWER W/ BOLTS/NUTS 2
COIL SPRINGS, REAR, W/ OEM RUBBER ISOLATOR SEATS 2
A-ARMS, FRONT LOWER W/ BOLTS/NUTS 2
STEERING
UPPER STEERING SHAFT, NON-TILT ONLY
STEERING RACK W/ TIE RODS, ENDS, BOOTS, NUTS, MOUNT BUSHINGS 1
ELECTRICAL
WIRING HARNESS, ENGINE
HORNS
IGNITION CYLINDER WITH KEY 1
VACUUM RESERVOIR, CYLINDER SHAPED, BLACK PLASTIC 1
GROUND STRAP, BATTERY CABLE WITH TERMINAL 1
WIRING HARNESS, REAR 1
COIL, STARTER SOLENOID
WIRING HARNESS, DASH 1
WIRING HARNESS, FRONT 1
EEC IV COMPUTER W/ PLASTIC HOLDER
WIRING HARNESS, TRANSMISSION 1
MISCELLANEOUS
PEDAL BOX, BRAKE CLIP AND (2) PLASTIC WASHERS
RADIATOR CAP
FOG LIGHTS 2
INTERIOR REAR VIEW MIRROR AND MOUNT 1
ACCELERATOR PEDAL
Anyhow, both are (or will be) great cars and real track beasts, but not your ideal road car.
http://www.superformance.com/cars.asp?flash=0
It's interesting how religious the cobra folks get, almost but not quite as much as the Porsche Spyder folks. They can get downright nasty when discussing various kits.
Blah blah blah...move over z06 and 911 turbo, yeah right. I'd rather have those everyday cars than a kit car with no radio, a/c, and probably no better for headaches than a jackhammer.
Sam
Sam
??? eh... i did not mean any disrespect for the other automobiles?? blah blah blah??
I just think it would be cool to have one of these... It would be a car that i wouldn't mind thrashing the crap out of on a road course week end and week out...
Oh and the no radio..not interior..no a/c... and thrashing headache would all be part of the fun of that car.. There is always something good about raw.. (though the lap of luxery is also nice at times). Not only that this car is extremely lightweight... meaning incredibly tossible..
For everyone who says that the z06 is a value (though it is) has not checked this baby out... for under 20 grand you aren't going to touch this thing on a road course, drag strip, or much anything else for that matter unless you buy a motorcycle.
It also has some of that old school nostalgia and sex appeal to it.
Many of the kitcars sound great on paper, but when it comes to building them, and maintaining them, I think most are a nightmare. From what I have seen (i did attempt to sell Westfield Kitcars for a few months), it looks like you have to be really committed (and creative) in order to complete some of these kits. Resale sucks donkey's balls, and I doubt any of them are really very reliable.
a guy spent 300+ hours working on my Lotus Super 7 kit before I canned that. Another guy who decided to do it himself (i think he lives in Oregon) spent close to 300 hours to finally get his together and it is not any faster than his lotus elise (which weighs 700lbs more), and it leaks oil here, and there and everywhere.
If you go with the turn-key versions of these, the depreciation is probably 40% if you can even find someone to buy it.
Just my opinion..... I am not even sure how kitcar places stay in business unless their margins are 80%. I don't think there are too many people beating down the doors to buy these things.?
