What is binding?
Old 04-15-2005 | 05:43 PM
New Concept's Avatar
Banned
Default What is binding?
Can somebody explain what bonding is in awd cars?
I was told its the same feeling you get inside the cabin as if the car is about to stall (but not always so drastic).
Old 04-15-2005 | 09:33 PM
FormulaBMWracer's Avatar
"binding"is a term that is used when a cars chassis has too much grip throughout...when racing 125 karts, or any type of kart racing we would use "biking" as the term for "binding" meaning too much grip throughout the corners and the kart would actually pick itself up off the inside of the corners. So put that into a bigger chassis/AWD car and there you have it. And im assuming you are talking about binding up when you are launching the car?
Old 04-17-2005 | 12:52 AM
Banned
Well I never knew that. And was not reffering to launching.
The reason I asked was b/c when my friend makes a turn in his audi a4 quattro the car starts to shake- and for some reason I thought it was called binding. You guys wouldnt happen to know what causes that would you?
Old 04-17-2005 | 04:33 AM
Grimace's Avatar
That sounds like he's got a bad driveline joint. Are you talking really sharp, low speed turns or just "regular" stuff?
Old 04-17-2005 | 05:50 AM
rai's Avatar
rai
Not sure about this, but I have an AWD sienna. Once in a while when I'm doing a max acceleration while turning sharply with low grip surface the stability control starts in with the brakes. Causes a little shudder.
Stability control can cut engine power as well. Wonder if that could be it? Might try switching off SC if he has it to see what happens.
Old 04-17-2005 | 05:55 AM
rai's Avatar
rai
There is a thing with 4x4 trucks where they are NOT supposed to be driven on dry pavement b/c the wheels get too much traction. The problem may be called binding b/c when you turn the wheels are moving at different speeds and need to slip or else can hurt the drivetrain.
This is only with old fashon 4-on the floor systems. Most cars and a lot of SUVs now have a different system that is usually called AWD or on demand AWD that have no problem with high traction.
grovefromnh
01-08-2010 12:06 AM
grovefromnh
12-31-2009 07:49 AM
dannykim
19
02-02-2002 10:05 AM
Quick Reply: What is binding?
