TSX timing chain
TSX timing chain
my dd 2004 tsx threw a code for timing chain/cam sensor etc...drove it to work...left work wouldnt start...well it did but it was like it was running on 2 cylinders or out of gas...wouldnt go above 2500rpm or so...it got towed and the shop says they are going tio replace the timing chain (800!!??!!)
now i hope it just jumped a few....would it even start if i was broken chain? or bent valves...???
i need help please!!
If it was a broken chain you wouldnt start at all. It could have jumped a few links, but that would most likely mean your tensioner is bad/timing chain is bad. If the chain jumped enough links, and the engine is a interference type (probably is, right? its a honda for crying out loud..) then you might have bent valves, but I doubt it did if you didnt hear loud clacking noises...
Engine: ENGINE AND ENGINE COOLING:ENGINE
Service Bulletin Number: 90105
NHTSA Number: 10018108
Model Years Affected: 2004, 2005
Date of Bulletin: 12/2005
Bulletin Summary: A LOOSE TIMING CHAIN, A DEFECTIVE AUTO TENSIONER, A LOOSE TIMING CHAIN SPROCKET, LOW ENGINE OIL PRESSURE OR A MOMENTARILY SEIZED CAMSHAFT CAN CAUSE AN INTERMITTENT DTC.
i just found this!!does it mean anything good...(is it a recall)
