Repair questions - Need your help
Below is a list of the estimate to repair so far. I need to know as much info as I can to make sure I get what I want. Your help is greatly appreciated. Thanks in advance.
QUARTER PANEL
Repair - R quarter outer panel
Refinish - R quarter panel outside
Full refinish within panel - no blend
Repair - L quarter outer panel
Refinish - L quarter panel outside
Remove/install - R quarter antenna assembly
LUGGAGE LID
Remove/install - Luggage lid panel
Refinish - Luggage lid outside
Refinish - Luggage Lid underside
Remove/replace - Luggage lid latch assy
Remove/replace - R luggage lid hinge
Refinish - R hinge
Remove/replace - L luggage lid hinge
Refinish - L hinge
Remove/replace - luggage lid emblem
REAR BODY
Remove/replace - Rear body panel
Refinish - Rear body panel
Refinish - Add for edge & inside
Remove/replace - Rear body vent
REAR LAMPS
Remove/replace - R rear combination lamp assembly
Remove/replace - L rear combination lamp assembly
Remove/replace - Stop lamp assembly
REAR BUMPER
Remove/replace - Rear bumper cover
Refinish - Rear bumper cover
Remove/replace - Rear bumper clip
Remove/replace - Rear bumper screw
Remove/replace - R rear bumper impact absorber
Remove/replace - L rear bumper impact absorber
Remove/replace - R rear bumper absorber spacer
Remove/replace - L rear bumper absorber spacer
Remove/replace - Rear bumper reinforcement
Add'l Opr - Clear coat
Add'l cost - paint/materials
Repair - Set up and measure
Repair - Additional full-body
Remove/replace - Seam sealer
QUARTER PANEL
LUGGAGE LID
Refinish - R hinge
Refinish - L hinge
REAR BODY
REAR LAMPS
REAR BUMPER
Uh, ok, well then...pics would be nice to see what they're claiming can be fixed and what needs to be replaced. Also, there's no pricing to compare if they're reaming you or not. And knowing what car this is will be important in determing part pricing.
I'm not worried about pricing... just the repairs listed. Are they doing anything to my frame that is listed on that list?
Like, for instance, at the bottom where it says: Repair - Additional Full body..what is that?
I want to make sure they are not repairing something that would best be replaced. I will try to get some photos today...thanks.
rocket71
03-16-2012 09:02 PM
