Plastic composite engines.
Originally Posted by Lice Locket,Dec 1 2009, 07:31 AM
That's pretty cool. They said Glocks would fall apart because they were made from plastics, but they are now the gold standard of reliability in handguns.
I think the coolest part is that if you could make long term reliable engines from composite materials and be able to drop 200 or more pounds off a car. Better handling, acceleration, braking, mpg and more fun to drive.
Its still probably 10 years or more away, but seeing part of the future of auto tech is always neat.
The article referenced composite intake manifolds had been used quite a bit. I had never heard of this.
Granted, racing applications are severe, but there is no comment about the longevity of the engines. Can they run for 150K miles? Can they handle -40*F to 125*F ambient temperatures? How about constant start-up/shut-down problems with varied cooling rates of thermoset plastics vs metals in the engine? Plastics are generally quite brittle in cold temperatures and I doubt these are much different.
Interesting read.
If the plastic composites can hold up the stress and heat, it can definitely be the future material for engines.
Just look at the weight savings.
415lbs => 200lbs
Dan
415lbs => 200lbs
Dan
