looking for some specific info
so i'm working on a project at work, and the short of it is i'm trying to design a braking system using some similar friction material that is used for GTR track pads.
what i'm looking for is caliper/brake system info such as piston size, line pressure, number of pistons, etc...does anyone have any good ideas where to find something like this? most of my searches have only turned up such info as rotor size, general info like that.
thanks
thanks
You must increase your maths, and then do them to derive the infos you want.
Seriously though. Line pressure can be derived from the following:
Area of a circle = Pi * r^2 (r is radius)
Force = Pressure * Area
-Size of the master cylinder
-Size of slave cylinder
-How much force someone puts on the brake pedal with their foot. This adds a bit of subjectivity. I guess the manufacturers have a magic number (twice what a strong man can leg press?), and then use 1.5 as MAX pressure they want to see in the line.
Originally Posted by sparrow,Oct 8 2010, 06:35 AM
To Op: I would suggest you get in touch with an oem brake system maker/manufacture/vendor. If you have the inputs from your system, they should be able to size it.
Otherwise, you really are going to need to know some "maths" and do some real engineering work. Basic hydraulics aren't too difficult.
Originally Posted by zachismisitok,Oct 8 2010, 10:44 AM
Way to be a jack ass- He was only trying to help.
Originally Posted by sparrow,Oct 8 2010, 07:02 AM
Ummmm I know this. I was not trying to imply that he was wrong. His understanding of the material is far greater than mine. I was referring to myself with the picture but thanx for name calling.
Originally Posted by zachismisitok,Oct 8 2010, 02:05 PM
ahhh, I completely missed the point, blame cathodic protection equations- sry broski.
clarkster009
06-14-2016 10:14 AM
clarkster009
12-17-2011 11:36 AM
