View Poll Results: HP -> Acceleration... not Torque!
Voters: 203. You may not vote on this poll
#42
Originally posted by FYRHWK1
As to the original question of hp vs tq. say you up your S2K's redline from 9K to 10, your car will gain hp, but it won't accelerate any faster, you'll hold gear longer, but you won't accelerate faster unless you shorten your gearing accordingly
You can do the experiment by shifting early. If you don't accelerate slower by shifting early then I'll concede you are right
#43
Okay, D2002, I agree you did well pose the question.
On my last post, a clarifier:
Depends what one means by "accelerate faster". If torque doesn't go up, yes you do not get increased accel (higher m/s2) than you had a fraction of a second ago. But you will accel better than if you did not have the extra rpm, and thus had to upshift. Result is a better 0-60, 1/4-mi, etc. Which I take to mean "accelerate faster".
And I agree with micah as do I think most here. Like high revs, like shifting, S2000=good. Otherwise S2000=probably not for you.
#45
You can't measure HP, you can only calculate it from the torque, how would you measure it? a dynomometer? that measures via the turning force on a drum, torque. flywheel dyno? same principal but with the elimination of the driveline.
My bathrooom scale has a strain gauge internally that works based on resistance; that doesn't mean that my bathroom scale is measuring my resistance! It's an internal step to the device.
Power is quite easy to measure directly without a specific internal torque measurement step. Ever ridden one of those stationary bikes hooked up to a generator and a light bulb? There's no torque being measured there.
#47
what is HP? torque over time
Again, there is no way that a dyno can measure your engine's torque unless you know the intermediate gear ratios. But the dyno can tell how much POWER your engine is putting out, minus friction. The fact that a dyno may measure torque internally is simply a confounding factor in this conversation, which is about flywheel power vs torque.
Anyone who's familiar with dynos can tell you that a dyno can tell you power without knowing anything else, but to get torque from it, you need to give it all kinds of information about tire diameter, gearing, and engine revs. This tells you that power is what's being measured and torque is what's being calculated. That's why the definition of a dynamometer is a device that measures power.
And dynos measure the turning force of the wheels,
[QUOTE]but if you metered the energy put out by the generator you would have the converted equivalent of however much torque you're putting out
#48
Originally posted by micah
If you were thinking this, I think I see the source of the confusion. HP is power; or WORK over time, or torque TIMES revs; but not torque over time, at all.
#49
Call me crazy, but this is how I see it:
HP gets the RPMs up, torque spins the wheels.
I could be incredibly wrong about that, but it works in my head.
-Matt
-Matt
