Heat Bog
Before I did this I let my car sit over night to have minimum spillage of coolant. It was worth it! I only lost about l/8th of a cup.
First find this coolant hose next to your intake manifold and disconnect the end where I'm pointing and connect one end of your bypass hose.
http://www.tsxclub.com/forums/member...715-133703.jpg
I routed mine on top of the intake manifold. It made a small burn mark on my hood insolation but nothing I'm worried about. You can try routing it under the intake manifold but you may need more hose.
http://www.tsxclub.com/forums/member...715-133718.jpg
Finally disconnect this end of the coolant hose and connect the other end of your bypass hose and you are done! If you have trouble finding this end just trace the hose back from the hose in the first pic. Also I forgot the size of the hose I used but it was fuel line. I think I used about a foot of hose. Its been on for 2 years with no problems (knock on wood). If you have any questions feel free to ask. This is not a guarantee fix but it helped me. Hope this helps you!
http://www.tsxclub.com/forums/member...715-133736.jpg
parisbishop
03-14-2011 02:28 PM
