Brake and Clutch fluid - how much do I need?
Alright guys, I decided on Carbone Lorraine pads, Spiegler lines and whatever fluid I decide on.
I was curious how much fluid I need to change the brake and clutch fluid.
Thanks!
Thanks!
this is for a bike?, you are doing the front only i hope?
get the 500ml bottle, if you buy from a automotive shop you will save compared to bike shop prices.
verify all the hardware is there for the brake lines, usually something is missing or not matching up, different threads etc.
get some speed bleaders
replace the rear:
-if you got money to burn do it?
normal riding should not use the rear. may be in the parking lot.
i say this in fear it will start a huge discussion here. back in the days of old when motorcycles were twice as heavy and and half as fast using the rear made sense.
The rear brake should always be used as well. Why would you not want to fully utilize both brakes in any situation? Either stopping quicker if needed or putting less wear on the front brake while achieving better balance.
Originally Posted by jah,Aug 17 2008, 06:21 AM
i say this in fear it will start a huge discussion here. back in the days of old ... using the rear made sense.
anyways get 500ml of fluid, look at some speed bleeders.
cheers
I was taught in the MSF course to always use it and I always have. If you don't use it all the time, then you run a much greater risk of locking it when you do use it.
Besides, on my bike they are linked.
