Intercooled engine now features advanced MIVEC technology, producing higher torque and better overall performance
The 2006 Lancer Evolution features a standard two-liter DOHC 16-valve I-4 intercooled turbocharged engine, which is enhanced this year with variable valve technology (VVT). This Mitsubishi Innovative Valve timing and lift Electronic Control (MIVEC) system utilizes a VVT sprocket to optimize valve timing relative to the engine condition. This technological advancement, combined with enhancements to the vehicle's turbocharger, produces higher torque and better response for improved engine performance across the Lancer Evolution IX's full rpm range. The improved powerplant reaches 286 horsepower at 6,500 rpm and 289 foot-pounds of torque at a very low 3,500 rpm.
New gear ratios on the models' standard five-speed manual transmission take full advantage of the increased torque to improve the vehicle's already blistering acceleration. This transmission is derived from the Mitsubishi close-ratio competition gearbox but has a modified top gear ratio for improved high-speed cruising. The Lancer Evolution MR features a six-speed close-ratio manual transmission.
All three Evolution models feature a rally-tuned fully independent suspension; the MR utilizes Bilstein" monotube shock absorbers. Full-time all-wheel drive with an active center differential (ACD) provides improved steering response and better traction. Three ACD modes are provided - tarmac, gravel and snow - to enable quicker controlled response for changes in road conditions. The Lancer Evolution also features front- and rear-limited slip differentials, and four-wheel ventilated Brembo disc brakes to help control the beast.
Specifications
Engine
Type: Inline-4, Turbocharged
Displacement cu in (cc): 122 (1997)
Power bhp (kW) at RPM: 286(213) / 6500
Torque lb-ft (Nm) at RPM: 289(392) / 3500
Redline at RPM: 7000
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 235/45 R17
Driveline: All Wheel Drive
Exterior Dimensions & Weight
Length
Specifications
Engine
Brakes & Tires
Length
man I don't have a problem with the looks of the evo, but this new one is disgusting!!! with those holes!!! it just ruins it!!, I don't think even fog lights could fix the ugliness, they just need to keep last years bumper, but the taillights are a plus.
