2005 Ford Mustang Coupe Concept
the better parts are
Technical Specs
Drivetrain layout Front engine, rear-wheel drive
Engine type 90-degree MOD V-8, cast-iron block, aluminum heads, belt-driven supercharger with liquid-to-air intercooler
Valve gear DOHC, 4 valves per cylinder
Bore/stroke, in/mm 3.55 x 3.54/90.2 x 90
Displacement, in/mm 280.8 / 4,601
Compression ratio 8.5:1
Horsepower @ rpm 400 @ 6,000 (estimated)
Torque @ rpm 390 @ 3,500
Redline, rpm 6,500
Transmission 6-speed manual (coupe)
5-speed automatic (convertible)
Axle ratio 3.55:1
Final-drive ratio 2.24:1
Chassis
Brakes Brembo 13.8-in vented disc
Wheels (front)
(rear) 20 in x 8.5 in aluminum
20 in x 9.5 in aluminum
Tires (front)
(rear) 245/40ZR20 BFGoodrich g-force T/A
275/35ZR20 BFGoodrich g-force T/A
or check this out
http://www.stangnet.com/mustanggtconcept/
Technical Specs
Redline, rpm 6,500
Axle ratio 3.55:1
Chassis
Wheels (front)
Tires (front)
or check this out
Well I had one like the red one. Can't tell in the tiny picture if it's a 65 or 66. I like the the coupe, saw it on Autoweek, on Detroit channel 56 PBS on Sunday. He was talking to Mays from Ford about all the concepts to be at the Auto Show. Also had a segment with Chrysler/Dodge on the show.
