05' and 06' compatibility?
I wanted to know if anyone had info regarding seat and steering wheel compatibility between an 05' and 06' MY.
I have an 06' and all I'm finding are wheels and seats from 05 and below. I understand that the 06' is the first year of dual stage airbags. If I use an 05' steering wheel will that cause issues with the system or will it just be a single stage airbag with no computer issues?
Also if I have an 05' seat will there be issues with dual stage as well?
Any help will be much appreciated!
The passenger Side seat will not bolt in properly. Next issue is the SRS system will not work properly either since the 06+ have the SRS weight sensors built into the passenger seat. If the seat is not connected you'll have the SRS error light.
Next, the '05 Airbag will not fit an '06, the harness is different. So no go there.
Lastly, since none of the airbags or sensors will be operating you don't have to concern yourself with dualstage nonsense because the SRS system is disabled if there is anything thing that causes a faulty SRS.
In other words - find '06-'09 stuff if airbag functionality is important to you.
