What is the proper top-down behavior?
I don't remember this happening on my first car, but now I don't remember what the correct sequence of events is when you put down the top.
I unlock the latches and pull the ROOF switch. My driver's side window cracks a bit (like an inch) while the passenger window drops the whole way into the door. The top retracts normally. Should both windows crack only a little bit, or both retract all the way, or is this normal behavior for a 2001?
What should happen when you put the top up?
Originally Posted by The Raptor,Mar 31 2006, 01:21 PM
Also, better check the window pressure actuator fluid reservoir. You may need to add fluid.
