California - Southern California S2000 Owners Southern California S2000 Owners
Tire Fitment Question
Old 11-17-2008, 02:39 PM
FilthyAp2's Avatar
Don't track at all..... been wanting too but car is not setup to even have a great run....
I guess i just wanted to run a wide tire but i was mostly concerned about the rears rubbing again and then having to run -camber to clear the 255's
FilthyAp2 is offline
Old 11-17-2008, 02:54 PM
Chris_Lum's Avatar
oh ic. well i have the 17x9 +45 rears w/ 255s running the UK spec alignment. i don't rub at all w/ the fenders rolled and tab relocated. So you should be fine, depending on what alignment specs you go with.
Chris_Lum is offline
Old 11-17-2008, 03:35 PM
Wraeththu's Avatar
Originally Posted by 04stoner,Nov 17 2008, 03:10 PM
What do you mean by this Marcos?
meaning the car wont oversteer as much, which it has a horrible tendency to do anyways.
I would never run 255 all around, unless your a pro
235 fronts
255 rear
try and account for the sidewall difference.
Wraeththu is offline
Old 11-17-2008, 04:06 PM
FilthyAp2's Avatar
235 fronts
255 rear
I see!
Well i have 235-45 up front..... 255-40 should match up pretty damn good right?
Old 11-17-2008, 04:11 PM
Chris_Lum's Avatar
255/40 is a 102mm sidewall and 235/45 is a 105.75mm sidewall...so your front sidewalls will be larger by 3.75mm. shouldn't be too noticeable.
Old 11-17-2008, 04:15 PM
HUYS2200's Avatar
You suck at tires knowledge.
HUYS2200 is offline
Old 11-17-2008, 04:26 PM
Wraeththu's Avatar
pretty good
Old 11-17-2008, 06:25 PM
FilthyAp2's Avatar
Thanks guys!
Jc
Old 11-17-2008, 06:26 PM
FilthyAp2's Avatar
Closed
McFab
02-26-2013 02:12 AM
burglrdrift
02-22-2012 04:47 AM
whitt1
11-14-2011 02:50 PM
allHAWKedup
10-23-2011 08:50 PM
black02S
08-08-2008 05:12 PM
Quick Reply: Tire Fitment Question
