TCT Noise
TCT Noise
Can anyone around the Downey area verify that my TCT is the culprit for a rattling noise coming from under my car when the engine is started cold and whenever I tap the throttle under no load....
hmm...
It's oil pressure driven, typically anytime oil pressure is slightly worse you'll hear it more.
-Hot engine
-Low RPM
^ biggest contributors to the issue once its evolved. Doesn't exactly match what you're saying.
-Hot engine
-Low RPM
that could be the case when you tap the throttle... when your car is starting at cold then its normal, and then it goes away when the engine warms up, that happens to most s2k's even the new ones at low mileage. or if you put in new oil it seems to go away. but as for the throttle thing.. TCT could be it im not sure... Greg knows best
TCT usually makes that noise after the car has been running
you tube videos
[media]http://www.youtube.com/watch?v=_ZVrJIkrp-Q [/media]
its a known issue on the ap1. the chain tensioner is hydraulically assisted by oil pressure. if the oil is too thin the pin that guides the chain has an issue of not retracting all the way.
theres been a debated issue of mobil 1 causing this issue back in the day. its an easy fix...part is about 80 to 130 depending on where you get it
-a
you tube videos
-a
Actually i've been revving the engine right now that its warm and at very low rpm i get the kind of rattling noise by the exhaust manifold/vtec and tct area. it also is pretty loud inside the cabin. I know it isn't the throwout bearing because I get the noise when I depress the clutch in neutral and in gear.
BTW, I use Mobil 1
BTW, I use Mobil 1
Mobil 1 fades and becomes thin due to heat easily (like (A) already stated)..... this makes the TCT thing worse because with thin oil there's less pressure, it's also the reason it burns and leaves you with a low oil level quickly. I still like the oil however, especially for the price/value.
If it goes away when you accelerate and stomp on it but then comes back when you return to idle.... that's the tell tale sign of TCT issues.
Remove it and sandblast the worm gear then reinstall..... It's a bitch to get it pinned but it'll fix the issue. Otherwise order a new TCT from honda.
Changing oil will be a temp fix but.... it'll come back.
-Greg
-Greg
Do a search for sandblasting the worm gear. Billman is the one who came up with the idea and it definitely stops the noise. I've had it done on my TCT and for the last 10k miles there's no noise whatsoever. Saves you from spending $130 when the same thing is just going to happen again.
If only I had invented the paperclip.
