starter kill question
which color coded wires should i be looking at to remove the starter killer? took all the stuff out with my aftermarket alarm but car won't start and it's coming down to the starter kill which i can't figure out since i reconnected all the wires with their matching colors.
The starter kill requires a complete cut, it's not going to work otherwise. I used the black/white wire in the driver's kickpanel. It chils in a blue bracket plug close to the firewall. It's the only very thick wire in the plug. That relay used both ends of this cable, a constant positive wire and a 'ground when armed from the alarm brain'. You need to reconnect the starter cable.
Does the OEM alarm have a starter kill as i found out that not only does my car have the oem alarm but also the aftermarket ( which i took out). I left the oem alarm intact cause it was neatly and nicely put in place with all the oem plugs and such.
Originally Posted by cvjoint,Sep 5 2010, 02:03 PM
I didn't have an OEM alarm. It easy to try, get inside, arm it and try to start the car. The alarm will go off and the car won't start
Originally Posted by S2Kmonkee,Sep 5 2010, 05:16 PM
I found a local place that sells the key fob for the car so imma buy it first and try to see if the oem alarm still runs. Thanks alot for all the Q&A.
