California - Southern California S2000 Owners Southern California S2000 Owners
spark plugs recall? is it happening to my car?
Old 03-13-2004, 01:29 PM
toycar8's Avatar
whenever i hit my rpm slightly from 4000 and i let it fall back down, it don't idle to 1000 rpm. it goes straight to zero and the worst thing is my engine shakes like it's about to die but then right after it will come up to idle stage at 1000 rpm. what's going on with my car. pls help me.
Old 03-13-2004, 02:42 PM
xviper's Avatar
Not sure why you put this in "Meets and Events".
Old 03-14-2004, 06:45 AM
toycar8's Avatar
is there any way i could transfer this forum to the socal s2ki?
Old 03-14-2004, 07:34 AM
xviper's Avatar
I'll get one of the site mods to move it for you.
As for your problem, this has been reported a lot. It has to do with a combination of the MAP sensor and/or the idle air control solenoid/valve. Try the "MAP whack". Your MAP sensor is locate on top of your throttle body. Undo the wiring harness, take the rubber end of a screwdriver and firmly tap the top of the sensor several times, put the harness back and see if this helps. If it doesn't then you need to look at the IAC as mentioned above. Also, it won't hurt to reset the ECU. Look at the fuse legend in the driver's footwell. Find the "BACK UP" fuse and take it out for about a minute and put it back in (ignition OFF).
Old 03-14-2004, 08:54 AM
toycar8's Avatar
thanks for the input xviper. i'm gonna try to do that when i get home from work.
Old 03-14-2004, 09:00 AM
Mindcore's Avatar
Moving to Socal
Old 03-14-2004, 09:27 AM
toycar8's Avatar
thank you very much. pretty cool!
Old 03-14-2004, 08:57 PM
spoon us's Avatar
2001 honda s2000 spark plug recall go to youre nearest honda dealer they fix it for you for free....
Old 03-17-2004, 09:42 PM
toycar8's Avatar
i'm planning to purchase denso iridium spark plugs. would it make a difference?
toycar8's Avatar
i mean instead of purchasing another platinum.
Quick Reply: spark plugs recall? is it happening to my car?
