removing HID bulbs from headlite
since the search button is not workin do you have to remove the headlights to remove bulbs? i have never done it or looked at it yet but thinkin bout changing to differnt HID bulbs
thanks
thanks
Let me know how the change works ... been thinking about that also to a higher K. Not sure how many K the S is .... but I heard that it aint really worth it. More K = less visibility ..... thats what I heard. Let me know how this goes. Gud Luk!!!!
Also, I dont think you have to remove the Headlight ... unless you have huge paws!
Banned
You need a 4mm Torx bit with the hole in the middle, I forget the technical name for it. This is to remove the cover. After that, twist, and it should come out. The igniter and bulb is right under it.
Removing the headlight helps. The brackets, wires, and hoses will piss you off if you dont.
yea i saw this STI the other day at skool wit purple HIDs....man it looked nice....thanks for the info....i think our s2ks r at like 4300k...which is just like daylight
hahha ok i gotta decide wat K temp bulbs i'm gonna get....only if the search button works...does n e one kno when its ever gonna come back...i know other owners have done this before
also where do u get a Tamper Resistant Torx Bit...and do u really really need it?
