rear passenger side road noise
i keep hearing noises from my rear passenger side, i checked to see if it's the bearing and there was no play in the wheel when i tried to see if it wobbles when i had it up on jack stands from what my search told me to do. Can springs or worn brake pads causes more noise?
YA, realllly needing more info.
Bumps?
Forward + Reverse?
At a near stop?
Increases with speed?
Heavy or light throttle?
During Braking?
-Greg
Bumps?
Forward + Reverse?
At a near stop?
During Braking?
-Greg
ill try and answer to the best of my ability.
the noise is constant , only time i hear it is when im on the throttle with normal speed, no hard driving. I wouldn't say it increases with speed cause the noise seems to be constant, it doesn't get louder as i got faster.
Oh i forgot to add that a couple of weeks ago, my coilovers were swapped out for stock i haven't get an alignment yet would this also be the cause of the noise?
mine too.
rear passenger side.
I swap the AP1 rims replace the AP2 tims, didnt help.
I changed my rotors and brake pads, didnt help.
it got some high pitch sound when the road is uneven/bumps.
mine is OEM shock with Tein springs.
Originally Posted by SoCalAp2,Nov 11 2009, 10:27 PM
high pitch? around 45mph? diff? lol
also does anybody know how to tell if an axle is damage?
no sound if the road is flat.
at high speed i cant hear anything, may be exhaust sound covered it.
but i know my rear passenger side shake between75-85mph, i think this is 2 different problem tho.
Originally Posted by S2Kmonkee,Nov 11 2009, 11:31 PM
bearings also grind/ make whining noises from what i heard....... it all depends on how the bearing is damage but from what i was reading when i searched, obvious sign is wobbling which my car does none.....
you can hear noise especially when you turn one side, depends which bearing goes bad.
