Need OEM CD Changer Install Template
I just bought a used OEM CD changer from a board member; however, it did not come with the template for mounting the CD changer cage. Would anyone happen to have one handy that I can borrow, or someone with it that can possible scan it and email it to me? BTW, do you really need the template to do the install and do you need the special tool to tigthen the flange-bolt?
I would greatly appreciate any help.
Over the weekend, I was able to hook-up the cd changer, well kind-of. I installed the BUS cable from the cd changer to the head-unit and everything is working. However, I'm unable to mount the cd change cage to the trunk because I'm unable to tighten the two jack nuts without the special tool.
I called the local Honda dealer and they wanted to charge $81 just to drill one hole and tighten three bolts. What a rip off!
Anyhow, anyone has the 'special tool' I can BORROW or BUY from you?
My changer is currently just sitting above the tools compartment of the trunk.
Try PM'ing oatnet. I recall him posting about a CD changer... I think it was some problems he had buying it from another member, which is beside the point but maybe he can help you on your install.
