my clutch grinds in 1 gear only
Originally Posted by Millenion LTD,Aug 6 2010, 03:33 PM
well, if you dont step on the clutch pedal and shove the shift knob into all the other gears, im pretty sure they all will grind as well
Another fellow s2ki member had a similiar problem. It ended up being his pilot or throwout bearing. Try flushing the clutch fluid and replacing it. Does it do it only in first gear? Have you tried to start from 2nd gear? Not that you should just trying to picture the problem.
That doesn't sound to well. I'll have a spare AP1 trans in about a week if you need it. Try to take it to a shop and have them give you some input but it might be the gears in the transmission.
