California - Southern California S2000 Owners Southern California S2000 Owners
Hub bearing
Old 02-29-2008, 10:53 AM
Dinnyin's Avatar
Default Hub bearing
Car says "wumpa, wumpa, wumpa" so I took it in. RR Hub bearing (?) is failing. Need a new one.
$390!
just griping, it's not money I was planning to have to spend...
I guess a few hundred bucks every so often isn't too much to ask for such a car at almost 100k miles.
but still...
Old 02-29-2008, 11:55 AM
s2kride's Avatar
I feel your pain. Had to do the same thing, but twice on right rear. All because I changed the bearing, but not the hub. Although, it didn't cost me as much, because I had a friend do it for me.
Old 02-29-2008, 12:00 PM
B.C.'s Avatar
If you don't replace it soon, it will be an drive shaft, then diffy.
Old 02-29-2008, 01:12 PM
chairmnofthboard's Avatar
It could be the axle if it only does it under acceleration.
Old 02-29-2008, 01:14 PM
05TurboS2k's Avatar
already did mine at like 20,000 miles
Old 02-29-2008, 01:15 PM
jari8378's Avatar
hmmm i was about to ask the same thing, if its only under acceleration, then its your cv joints. swap them
Old 02-29-2008, 10:32 PM
kreestofur's Avatar
i feel you. i had mine done couple months back.
Old 02-29-2008, 10:40 PM
reecespieces's Avatar
Do you have extended warranty? I believe it'll cover that
Old 03-01-2008, 06:59 PM
Dinnyin's Avatar
extended warranty was over like 25,000 mile ago
had it replaced, wumpa wumpa s gone, so I assume that means it wasn't the joints, axel, etc.
Old 03-01-2008, 07:10 PM
Quick Reply: Hub bearing
