how do 4.57 gears work?
Originally Posted by dyhppy,Aug 17 2005, 02:26 AM
does it just shorten each gear so that the high revs come faster, giving power sooner?
As I understand it:
Gears do nothing for power, but they change the availability of power at a given speed. Your car makes power from 0-8000rpm. In first gear, (simplistically), lets say you can go to 40mph stock. Putting shorter gears in will change it so you can only go to 30mph (simplistically). However, since the same amount of power is being delivered to go 0-30 instead of 0-40, you would reach that speed faster than you would with the stock gears.
You get faster acceleration with top speed/high cruising RPM as a trade-off.
get on a 10 speed in a gear(4.57). put a buddy on the exact 10 speed next to you in a larger gear(4.10).
race him down about a block, you will kick his a$$ each time if you are the same build unless he is like an olympic cyclist. but just as in the car, he will eventually catch up to you and pass you over a longer distance.
you will have better acceleration, but he will have a better top speed.
Originally Posted by gusrock77,Aug 17 2005, 11:30 AM
...so then, is it even worth going with a 4.57? ...how low does your top speed drop?
....damn 70mhp on the top of 3rd? ...i dont know if id like that ...anyone in here with it installed? ...anyone recommend it ..or even in the south bay area that wouldnt mind taking me on a test drive to see the difference
