Help with NRG Damper install
I have had my NRG ETD sitting in my room for a while now and want to install it. I don't want to remove the heat shield, I rather cut a hole in for the ETD to go thru. I also have a puddymount bracket.
Does anyone have a DIY out there or some kind of measurements as to where you drill on the heat shield?
Jc
Jc
Originally Posted by terahertz,Jul 13 2009, 10:07 AM
iirc puddymod had a image or pdf of a template you just print out and place over the heatshield to see where to drill...
Originally Posted by Shadow_S2K,Jul 13 2009, 10:08 AM
You would have to remove the heat shield to accurately cut it anyways. Removing the oem heat shield is pretty simple, and takes like a minute.
Last time I looked at it, it seemed kind of complicated towards the firewall. I'll take a closer look tomorrow when I'm off.
Thanks Guys
