California - Southern California S2000 Owners Southern California S2000 Owners
help keeping me from rubbing~!
Old 01-19-2009, 05:58 PM
notyourfriend's Avatar
Thumbs down help keeping me from rubbing~!
17x7.5 +48 (Front) and 17x9 +45 (Rear)
225F/255R tires
MY08 on H&R Coilovers at 350F/350R Lbs. spring rates
The space/gap is approx. : 1-1.5 inches Or 2 fingers.
UK Alignment.
The front is fine... I am planning to roll my REAR fenders... what else is necessary for these not to rub in the rear?
it's difficult to get an answer from the correct form nowadays. i apologize if this is not the correct forum, but i know MANY people from So. Cal run this combination. thanks, in advance.
notyourfriend is offline
Old 01-19-2009, 06:05 PM
krnmike's Avatar
roll is all you will need to do. unfortunately there's chance that it may make little dimples on the outer side.
if you also do a pull on the rear fender, that would actually be changing the whole shape.
If you roll the rear and it isnt enough, try more camber. But just rolling should be enough.
krnmike is offline
Old 01-19-2009, 06:14 PM
Gunshow's Avatar
Rolling the rear is all that would be needed. The fronts are safe.
You can PM smirf05s2k to roll the rears
Gunshow is offline
Old 01-19-2009, 06:21 PM
marlonRocks's Avatar
personally, i prefer to "cut" the rears instead of rolling. pm me if you need help or want more info.
marlonRocks is offline
Old 01-19-2009, 06:23 PM
lychyrychy's Avatar
sorry to thread jack but if I already rolled can i still cut?
lychyrychy is offline
Old 01-19-2009, 06:25 PM
well... i was told i would need to CUT a portion of the bumper AND relocate the tab.
how correct is that statement?
Old 01-19-2009, 06:26 PM
lychyrychy's Avatar
nah you dont NEED to cut, roll is enough
I have the same set up for the rear, I'm more slammed on coilovers and probably 2.5 camber
Old 01-19-2009, 06:27 PM
latinochino's Avatar
255 rear
u need a roll and rear bumper tab relocated.
latinochino is offline
Old 01-19-2009, 06:35 PM
hmmm...not sure, but i assume you could, but why would you still need to?.....and the only reason why i prefer to cut instead of roll is that it looks much cleaner from the outside...when you roll, there is a chance that you could crack the paint...idk, thats my opinion
that's correct, you can cut the bumper and relocated the tab with a dremel, very simple job
Quick Reply: help keeping me from rubbing~!
