California - Southern California S2000 Owners Southern California S2000 Owners
Help with DIY Differential fluid change.
Old 08-09-2006, 11:44 PM
Banned
trivium's Avatar
Default Help with DIY Differential fluid change.
I am about to buy a bottle of le 607 and a low-pro aluminum jack for the fluid change. I wanted to know if I need to buy the supplementary washers seen on Ricks site when ordering the fluid. I also wanted to know if there are any threads out there that would help me with the swap. I searched but came back with irrelevant threads.Thanks for the help.
Old 08-09-2006, 11:55 PM
B.C.'s Avatar
https://www.s2ki.com/forums/index.php?showtopic=99995
Old 08-10-2006, 12:22 AM
Banned
trivium's Avatar
thanks a lot. One thing I didnt get completely was whether or not I HAVE to replace the washers.
Also, any alternatives to get the diff fluid in the diff?
Old 08-10-2006, 01:44 AM
iam7head's Avatar
i used the xviper way but damn, it's so tiring squeezing the last drop.
after changed my tranny, diff and my buddy's tranny and diff juice i found out autozone sells a pump that could undo the whole bottle in less than half a minute
Old 08-10-2006, 02:50 AM
B.C.'s Avatar
You can "flip" the washer and reuse. It's cheap anyways. Buy a new one.
How to pump? Go to AUTOZONE and ask for a fluid pumper.
BC
Old 08-10-2006, 05:52 AM
Bert05GPW's Avatar
They also have a big-assed evac pump for ~$11.
Old 08-10-2006, 08:26 AM
vonHultgren's Avatar
[QUOTE=Back-cracker,Aug 10 2006, 02:50 AM] You can "flip" the washer and reuse.
Old 08-10-2006, 08:32 AM
B.C.'s Avatar
[QUOTE=vonHultgren,Aug 10 2006, 09:26 AM] Hey there "flipper"......
Old 08-10-2006, 10:00 AM
Hockey's Avatar
Washers are cheap. Consider it a "treat" for the car.
The fluid pumps at Autozone are awesome. I've used a couple different styles from them and they all work.
Use a jackstand so that you don't get squished. And keep the back jacked up when filling so you get a little extra in there.
Congrats on DIYing it.
-Hockey
Old 08-10-2006, 10:10 AM
pantyraider's Avatar
I woudln't flip the washer. If you see an indentation in the washer then make sure you put it back in that same orientation. If the indentation is very large then I would use a new one.
Quick Reply: Help with DIY Differential fluid change.
