California - Southern California S2000 Owners Southern California S2000 Owners
ECU Reset
Old 05-30-2007, 09:55 PM
micron1's Avatar
Default ECU Reset
I have been reading about ECU reseting on the forum and it's benefits. However, I feel that one way should be better than the others. So which is best and is most safe for the car??
1- Pull the positive terminal on battery 2-Pull Ecu Fuse 3-Pull Ecu plug under hood
As well, I'm assumming all of these would be done w/the engine off? Does the
ignition need to be on?? Thanks, new S2k Owner
Old 05-30-2007, 10:04 PM
jdmgpw04's Avatar
oh boy
put your flame suit on...
Old 05-30-2007, 10:31 PM
s2k_dreams's Avatar
Pull the ECU fuse from the fuseblock located on the driver's side kick panel. Engine should be off. Pull it for ten seconds then replace. Nothing else is needed. Use a fuse pulling tool so you don't damage the fuse.
Old 05-30-2007, 10:33 PM
Rio S2K's Avatar
Pull ECU fuse under the driverside dash, I believe it's a 15 amp fuse. Doesn't matter whether on or off because it will shut off engine anyway once you pull it. Give it 10 minutes then pop fuse back in and start engine.
Old 05-30-2007, 10:34 PM
Rio S2K's Avatar
The fuse pulling tool is actually right there in the fuse box panel, good tip nonetheless.
Old 05-30-2007, 11:19 PM
NFRS2kSi's Avatar
disconnect battery.
Old 05-31-2007, 01:49 AM
iam7head's Avatar
disconnect the neg side of the battery cable
let it sit for 5-10 minute
put it back
start the car
turn off all the electrical load
have it idle for 5-10 minute, dont rev or drive the car
Old 05-31-2007, 09:43 AM
AlexS2200's Avatar
Location: 13851 A Better Way #11D, Garden Grove, CA 92843
Type in on your control pad.
Up Up Down Down Left Right Left Right B A B A Select Start
and your good to go!
JK Sorry, just take off the negative battery terminal.
IMO - Your not going to see a noticable difference.
Old 05-31-2007, 10:00 AM
Rio S2K's Avatar
If you take off your negative battery cable then I hope you have your radio code because you will need to re-enter it to get it back.
Old 05-31-2007, 08:41 PM
s2k_dreams's Avatar
I did this but all it did was give me infinite turbo
Quick Reply: ECU Reset
