best method to remove 6mm hex from driveshaft?
i heard from someone that liquid wrench is the best move, and he SWORE by it. i'm going to pick some of that stuff up, i have one of the 6mm hexes out, but i dont want to risk stripping the others, should i try heat as well? anyone got any best practicies?
- Simba
- Simba
Originally Posted by HighTechAP1,Mar 29 2008, 06:36 PM
try a 6mm hex socket on a ratchet.
Have you considered a box-end style wrench? It should hold better in the confined area. Maybe one with an angled head. Use a mallet to "break" the bolts loose after you put some liquid wrench on it for a while. That should do it I'd imagine.
if i can't get this squared away in the morning, anyone down to make a housecall and help me w/ that driveshaft? i already tried loosening the nuts on the axles and those came free w/out a problem, so i know its just the mounts that i have to deal with.
if you can make it out to west corona (green river exit) i'll reward you handsomely...either w/ cold hard cash, or a boat load of beer
Whatever you do don't take the driveshaft off the car. It's a biatch if you have it laying there on the floor because there is no leverage.
I say soak it in liquid wrench or PB blaster. Then go at it with a mallet to the wrench to "snap" the bolts loose.
GL
GL
GL
GL
thanx for all the help guys...forget the tapping method, 6mm hex on a socket and a breaker bar FTW. got more done in honestly 5-10 minutes then i did in an hour of work the last two days. now all i have to do is separate that ball joint and drop the bad boy out
