battery or alternator?
But I really doubt MY04 will have a dead alternator just yet. Batteries only last about 2-4 years max
Originally Posted by iam7head,Sep 10 2007, 05:12 PM
all my honda's warning light didn't go off until it's about to die, i wouldn't trust my life on it to be honest.
btw, i think its foolish to test the alt by unplugging the negative terminal.
its just not a complete test. the voltage regulator could be blown and outputting over 16V. or still outputting 12V which will still run the car, but not the required 14.5V (yes, the charge warning light indicator will be on anyway).
the only real test is with a simple $5 voltmeter.
1.Fully Charge battery
2.Load Test Battery(CCA divided by 2 =load to test)for 15 seconds
3.Battery should hold at least 10 volts under load for 15 seconds.
If battery passes above test install on car.
Start car
Connect voltmeter. set to DC and proper scale(connect to battery leads)
Reading should be around 14 to 14.5
If voltage is lower check fuse
If fuse is good alternator is bad.
Note: any automotive battery after charging reads 15 volts or higher = junk battery.
hope this helps you.
Start car
got a new bat at pep boys.. their tester said bat needs replacing.
i wonder if it *always* throws a replace code.. jk
they only had ENERGIZER batteries in stock. i hope the bunny keeps going and going and going and going..
thanks for the tips guys.
