California - Central California & Sacramento Central California & Sacramento S2000 Owners
sound when braking...?
Old 04-01-2009, 08:10 PM
rxtech06's Avatar
Default sound when braking...?
there's a shrieking sound that i hear from my right rear and it's more obvious when i'm braking. but then even when rolling especially at higher speed (50mph), the sound is still there. when i make a slight turn, the sound comes up. when i reverse and turn to the right (getting out of the driveway), the sound comes
do my brakes need service?
i also need an alignment. i haven't done one since i slapped on the springs. does needing an alignment have anything to do w/ this issue?
i need to take care of it asap, it's irritating.
need your help!
Old 04-01-2009, 08:22 PM
rob.ok's Avatar
Sounds like the squeal stops are making noise. Better check your brake pads.....especially the inside pad which means removing the wheel and caliper to check.
I don't think that it has anything to do with the springs....but you should probably get an alignment...especially if you are concerned with performance. I always get an alignment when ever I change my ride height and suspension set up but a bad alignment for me means seconds on a race track....all it means on the street is poor tire wear.
Old 04-01-2009, 08:27 PM
rxtech06's Avatar
squeal stops? i've never heard of that. but yeah i'll look into it when i open her up and give an update. i'll post pics when i do.
Old 04-01-2009, 08:37 PM
rob.ok's Avatar
The are little springs on the inside brake pad. When the pad wears down the squeal stop hits the rotor and squeals.....Its a warning....it means that your basically running on just the backing plates. Many times the inside pad will wear more than the outside pad so just looking at it through the rim is not good enough.
Old 04-01-2009, 08:39 PM
FreerunSquad_s2k's Avatar
pat i got some new brake pads from my S
but there the fronts only i think
let me know if u need them
Old 04-01-2009, 11:31 PM
rxtech06's Avatar
are they new? how much you want 'em for?
my rears for now are more important, but i want to change them all anyways since i haven't done so when i bought the vehicle.
let's see what you got.
Old 04-01-2009, 11:42 PM
il jus give them to you haha
but let me ask my bro first and see if its on the back or the fronts..
Old 04-02-2009, 07:20 AM
rxtech06's Avatar
aiite good lookin out ken. let me know when you can get a hold of those cause i don't think it's recommended to drive until i get a new set.
can you still get discounts at dealerships? i just called barber honda and they charge about 60$ for the fronts and $60 for the rears. my uncle works at lexus and usually gets it at a cheaper price, but he's not picking up at the moment.
Old 04-02-2009, 07:36 AM
rxtech06's Avatar
they say it's recommended to have the rotors turned when changing out the brake pads... i was told that if i took them off myself and brought them over to like pep boys or something, it'll be approximately 10$/wheel to get 'em turned.
can anyone disagree?
Old 04-02-2009, 09:43 AM
nah i cant get dicounts no more
but didnt u hear i got laid off?
but jus feel your rotors if there warped and if it is then u should get it turn...but id still do it anyways haha...
but see if i still work at toyota i could of done that for free...but yea
ill call up my bro tonight and see what side there from
Quick Reply: sound when braking...?
