California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Where to buy? High Temp Nuts and bolts
Old 10-09-2006, 11:04 PM
Tobal's Avatar
Default Where to buy? High Temp Nuts and bolts
Where in the Bay Area or preferably near Oakland can you pick up some High Temperature nuts and bolts. I need them to mount on my High Flow cats.
Old 10-10-2006, 01:01 AM
MrChoi's Avatar
umm san leandro honda im guessing. they have an online parts catalog too. http://www.slhondaparts.com/browse.asp
Old 10-10-2006, 07:30 AM
RWD_RCKT's Avatar
Any stainless nut with anti-seize will be fine. Your local Orchard Supply / Home Depot people will have it.
Old 10-10-2006, 02:49 PM
DongTran's Avatar
How many cats are you mounting?
Old 10-10-2006, 03:35 PM
jack_krippter's Avatar
just remove the ice bag
Old 10-10-2006, 05:07 PM
Tobal's Avatar
Those will hold up with the temperature?
Old 10-10-2006, 10:48 PM
MrChoi's Avatar
loc-tite" will probably not hold. you need those lock nut that is pressure fitted. i would get it from the dealer or from that website i mentioned.
Old 10-10-2006, 11:09 PM
GizmoIsChinese's Avatar
I think you have to check the grade of the nuts and bolts. The grade at most home supply stores are not the correct grade for automotive use. Check machine shops or some of the smaller chains of auto stores.
Old 10-11-2006, 02:17 AM
SOHCmyDOHC's Avatar
Local Kragen's/Autozone.
Look for the HELP section and you should be able to find some bolts there. Mine came in a yellow package. I used Exhaust manifold studs w/ matching lock nuts (come hi-temp black) for about $17. Or you can find them also in black packages also. But the black packages were individual bolt/studs.
If you go for HONDA parts each stud is gonna cost you about $10 each plus nuts for about $3 each.
here is the link for the HONDA parts though.
http://www.slhondaparts.com/browse.asp?Mod...%7CEXHAUST+PIPE
Old 10-11-2006, 07:28 AM
RWD_RCKT's Avatar
Local Orchard Supply stuff is more than adequate. You need to get lock washers as well. Anti-seize is what you need. Loctite is a definite .
With catalytic converter bolts... the only problem you have is rust and general shite getting in the threads making it impossible to remove.
I have never seen a nut on a catalytic converter break from temperature.
Quick Reply: Where to buy? High Temp Nuts and bolts
