valve adjustment
sup guys
so today after work imma learn how to do a valve adjustment on my s2k
so i was wondering if ne one knew the valve specs so i space them correctly
my friend is a master mechanic so im not worried about doing it wrong i just need the specs
my car is a 2001 w 100k miles
thanx in advance
thanx in advance
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Taken from this thread:
https://www.s2ki.com/forums/index.php?showtopic=245555
intake (closer to driver side for LHD) : 0.008 - 0.010 in (0.21 - 0.25 mm)
exhaust (closer to passenger side for LHD) : 0.010 - 0.011 in (0.25 - 0.29 mm)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
![iamwithstupid.gif](https://www.s2ki.com/forums/images/smilies/iamwithstupid.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
Originally Posted by sunnyyan,Mar 10 2010, 11:10 AM
Any recommended milege intervals for a necessary valve adjustment? 45K on my S and redline occassionally. Thanks.
SY
SY
The exhaust side is tight and the intake side is usually loose from what I've seen.
Originally Posted by itS2Krazy,Mar 11 2010, 01:23 AM
i usually do mine every 15k. i think brians2000 mentioned somewhere that most s2k's should get it done around then. but i could be wrong.
I looked up the factory recommended interval for valve adjustment and its says "Adjust only if noisy".
Normally I would say follow MFG recommendations, but there has to be some time interval. Looked up some other high revving Honda motors (B18c5) and its recommended every 30K.
