Time to change fluids
Did my search&reshearch.
So here is what i got...
1.For the oil im using moble 1 10w30 with a honda filter
2.For the tranny im using honda MTF or GM syncromesh <---ive heard GM is much better
3.For the differential im using moble 1 75w90
4.50/50 antifreeze
I've done the oil change twice allready but its time for a full fluid change since i just hit 25000.
All of the above is correct to my understanding right? Or am i missing something or have something wrong?
Thanks in advance!
BTW... this kinda sucks feel like a noob, since im coming from a civic to a S2K never new there so much to do on a RWD. On the upperhand best upgrade ever!!
4.50/50 antifreeze
Thanks in advance!
Originally Posted by tek336,May 15 2006, 07:27 PM
do you have all the drain washers for the oil pan & trans along with the o-ring for the radiator drain plug? Other than that !
I believe the coolant is rated at 105k/5 years. If you do want to change it, you can just get the stuff at the honda dealer that already has 50% water.
For the tranny, there is some concern with the GM synchromesh formula with the AP2 since it has carbon syncros or something. If you aren't getting any grinds now, might as well stick with Honda.
well i know when the car is cold its a bit rough. when temp. is all good the only problem i have is that my 3rd feels slightly crunchy. Sometimes it will go in smooth or sometimes you can feel a slight crunch. So since i have a ap2 should i just stick with Honda or go with GM?
btw thanks for the input
