stock v-tec not worling no cel
please help!!!! bone stock s2000 vtec not engaging. so I check the vtec solenoid, oil pressure, oil sensor, oil level and no dtc codes at all. its a ap1 and the rpm just revs even after 6.5k please help thank you
v/r
James
So I think found the problem. I rigged up a homemade test light put power to the single wire vtec switch and ground straight to batt ground and test light came on after 6k rpm and vtec kick in. So I think it was a bad grind somewhere.
