California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Possible to over power VSA?
Old 10-09-2013, 07:57 PM
ES2K's Avatar
Default Possible to over power VSA?
It seems that my VSA does not take effect like it used to. I recently performed an unintentional massive burn out when spritely pulling away from a curb side parking space. Rear wheels spinning; back end starting to go sideways. It was fun, so I kept my foot in it a little longer and let the wheels spin. No flashing yellow lights on the dash board. Then it occurred to me that the on board nanny should have cut the gas and maybe applied some brakes. Is it possible to overpower VSA, or has my VSA failed?
T.
Old 10-09-2013, 09:29 PM
macr88's Avatar
Do you have flashpro
Old 10-10-2013, 05:08 AM
ES2K's Avatar
No.
Old 10-10-2013, 05:22 AM
rob-2's Avatar
Did you accidentally turn VSA off?
Old 10-10-2013, 10:45 PM
TougeHorseman's Avatar
Are you vin diesel?
Old 10-11-2013, 02:14 AM
andrewhake's Avatar
If your VSA has failed you will get a VSA light on your dashboard to let you know there is a problem with it. It sounds like you turned off VSA, and dumped the clutch.
I don't think there is such a thing as an "unintentional massive burnout" in an S2000.
Old 10-11-2013, 08:55 AM
bunta_garage's Avatar
massive burnout and s2000 are usually not in the same sentence... haha
Old 10-11-2013, 12:06 PM
thomsbrain's Avatar
Allow me to clear up what happened here:
OP dumped clutch, CDV kicked in, clutch slipped in a massive cloud of acrid smoke, OP thought he was "burning out." VSA never had to kick in because he never broke traction at the wheels.
[media]http://www.youtube.com/watch?v=-I43RVEYEKU[/media]
Old 10-12-2013, 12:26 PM
ES2K's Avatar
OK folks, it doesn't make sense, that's why I posted my question. VSA was not turned off. I have an AP1 FW and slave cylinder, no cdv, Blacktrax street clutch.
Cheers...
Old 10-14-2013, 01:09 PM
odb812's Avatar
Don't you just love it when everyone who responds to your thread thinks they're Don Rickles? Does your VSA light come on when you put the key in the ignition to the on position? It's not the most likely thing, but it is possible that there is a problem causing VSA to be disabled, but the light is burned out/not functioning so you don't know. Is your brake fluid topped up?
Quick Reply: Possible to over power VSA?
