California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Only one cylinder running lean?
Old 10-22-2007, 10:48 PM
SOHCmyDOHC's Avatar
Originally Posted by RWD_RCKT,Oct 22 2007, 08:10 PM
I don't have much experience with EVO motors, but 130psi for a one year old car sounds pretty low. My old Celica All-Trac was 8.6:1 and compression was 165psi!!! But low compression would just lead to being too rich so it must be me.
True huh?? My EG was 9.2:1 and CR was like 185
Old 10-23-2007, 08:00 AM
Sfkn2's Avatar
Hm.... good point, but I thought it's ok as long as all 4 cylinders are holding about the same pressure all the way across?
Old 10-23-2007, 08:15 AM
RWD_RCKT's Avatar
Even is definitely better than not. But there is a minimum specification for compression.
But honestly, there are so many ways to do a compression check that can lead to bogus answers. Your compression is probably fine. Because like I said before, low compression would dictate a RICH mixture.
Maybe this is just an EVO thing... kind of like how the S always run leanest on cyl #4 (so I've heard) kind of thing.
Old 10-23-2007, 08:17 AM
RWD_RCKT's Avatar
Another thing too... have you been driving the car hard or soft? Driving the car hard definitely could lean out the plug. But driving the car very easily can do that too. Federal emissions and gas mileage requirements are a motherfckr.
Old 10-23-2007, 09:29 AM
Sfkn2's Avatar
I do both types of driving... pretty soft around town unless I feel the need for speed.. Haha.
But running lean in ONLY one cylinder... that's what got me worried.
Old 10-23-2007, 09:32 AM
RWD_RCKT's Avatar
Can you take a detailed picture of the lean plug? And another of the plugs on either side of the lean cylinder??
Old 10-23-2007, 10:29 AM
Sfkn2's Avatar
I already tossed the old plugs and replaced them with the 1 step colder plugs. I'll pull them out this weekend and see if the same thing still occurs.
Thanks for the help, guys!
Old 10-23-2007, 01:55 PM
macr88's Avatar
Originally Posted by Sfkn2,Oct 22 2007, 12:08 AM
Don't worry, Mac. I'm probably coming back soon. My lady has been thinking about picking up a new S... She already has plans for the Laguna Blue. LOL.
Charlie, did you swap injectors?
You said you got new injectors and a tune. I'm not sure if they can be adjusted individually but a swap of injectors will narrow things down. If the lean cylinder follows the injector then you know it's a bad injector if not then I guess it could be the tune. I think the computer would catch a loose injector connection?
Oh on the compression check did you only do one pump or was that several pumps till it reached max pressure.
Sweet can't wait to see your ladies sweet ride hehehehe.
Old 10-23-2007, 02:08 PM
Project22a's Avatar
It's a sign...
Old 10-23-2007, 02:19 PM
macr88's Avatar
Originally Posted by Project22a,Oct 23 2007, 03:08 PM
It's a sign...
A very expensive one
Quick Reply: Only one cylinder running lean?
