California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
O2 sensor giving any issues?
Old 05-08-2011, 10:00 PM
playground_the's Avatar
Originally Posted by tkeyyy
i thought that was just a corrosive protectant?
it is, but o2 only run 0.1V-5V an ohm of resistance will screw up the voltage big time. get all the stuff on the thread out, and go from there
Old 05-08-2011, 10:46 PM
SOHCmyDOHC's Avatar
if you did put a lot of antiseize then yeah it'll mess up the sensor. You just need very little.
Old 05-08-2011, 11:16 PM
tkeyyy's Avatar
Originally Posted by SOHCmyDOHC
Did you buy a direct replacement one ar a universal one where you splice? Also, do you have access to a scanner and can get the voltage output readings for the o2 sensors?
Did you run over something and it hit the O2 sensor?
got a replacement and it 'was' working right after i put it into my cat
i only put like a drop worth on it..
Old 05-08-2011, 11:21 PM
chViETnk's Avatar
could it be ur cat paul?
Old 05-08-2011, 11:48 PM
tkeyyy's Avatar
here's the odd part.. it was working fine with the cat.
with the TP, it's giving me a low voltage.
Old 05-08-2011, 11:57 PM
jerZs2k's Avatar
Get it check out at n1 bro. They who know right away why its doing that.
Old 05-09-2011, 09:00 AM
tkeyyy's Avatar
it'll also be a diagnostic -__-
i really don't think that corrosive paste will do anything. only thing i can do ATM is to check the threads on the o2 cel bung and the TP itself to see if it's making direct contact.
other than that, i have no idea
Old 05-09-2011, 09:25 AM
chViETnk's Avatar
oh your running a testpipe.. which brand?
Old 05-09-2011, 02:17 PM
tkeyyy's Avatar
megan resonated.
Old 05-09-2011, 02:47 PM
chViETnk's Avatar
not sure bout megan but when i had my 63mm berk test pipe it ran fine but when i switched to 70mm invidia my cel went on but i used the cel fix and it went away, have you tried that?
Quick Reply: O2 sensor giving any issues?
