California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
o2 sensor
Old 09-17-2012, 12:39 AM
  #31
iDashX's Avatar
Originally Posted by tkeyyy
Originally Posted by eklipz98' timestamp='1347863818' post='22016668
Mine don't smell, give it sniff!
Originally Posted by iDashX
can't smell anything from mines after everything is warmed up.
you guys both smoke though. i have a sensitive nose.
nope.. it don't smell. and Lisa loves the smell of gas...
Old 09-17-2012, 01:48 AM
  #32
whiteflash's Avatar
i don't see what the point is of having a HFC.. it's 2x more expensive and they both don't pass smog. you can still smell something from it too
Well taking my Asura HFC and knocking out the core effectively making it a TP; theres a 100000000000000000000x change in smell. If the HFC had a smell it was so miniscule that it was unnoticeable, the test pipe however
Old 09-17-2012, 11:18 AM
  #33
ics2ks's Avatar
02 sensor > 2 anti foulers > o2 bung. theres no way you should throw a CEL.
I made my own CEL fix with 2 anti foulers when I ran stock exhaust/63mm Spoon test pipe - never caught a CEL. Now I run the same CEL fix I made before on my J's 70RR and no CEL ever from that o2 sensor.
Old 09-17-2012, 12:52 PM
  #34
FlushAP1's Avatar
[/quote]
I don't think you're getting it. The CEL is because it's not detecting readings or proper readings from your O2 sensor. Moving the O2 sensor, couldn't possibly eliminate that problem. Getting a proper defouler can. Or just buy a proper test pipe (like from Berk) and call it a day. The O2 sensor needs to be read correctly. If you have an 06+ you could disable the secondary O2 sensor with a Flashpro.
[/quote]
I am running the berk test pipe. CEL still manages to come on.
Old 09-17-2012, 04:24 PM
  #35
tkeyyy's Avatar
hanzels did/does. i'm not sure why though..
Old 09-17-2012, 06:21 PM
  #36
Noodler's Avatar
Maybe you have a cel for some other problem?
Old 09-18-2012, 08:28 AM
  #37
ics2ks's Avatar
operator error. he probably didn't drill the anti fouler out enough.
Old 09-18-2012, 08:38 AM
  #38
TougeHorseman's Avatar
Worth looking into. Post the code, or it didn't happen.
Sexi2k
11-30-2017 04:29 AM
Ch0pper
06-12-2007 08:05 AM
nightcrawler7188
05-28-2007 05:15 PM
stena
02-16-2006 11:58 AM
SC-SUZUKA
11-07-2002 11:05 AM
Quick Reply: o2 sensor
