California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
o2 sensor
Old 09-16-2012, 06:27 PM
  #21
whiteflash's Avatar
Originally Posted by FlushAP1
Correct. & tucking the o2 that is originally supposed to be in the hole, else where. Such as being hidden/zip tied up top or wire tucked. If that makes any sense.I just want to know if any one has ever tried it, and if its a possible thing to do. The pros/cons.
I don't think you're getting it. The CEL is because it's not detecting readings or proper readings from your O2 sensor. Moving the O2 sensor, couldn't possibly eliminate that problem. Getting a proper defouler can. Or just buy a proper test pipe (like from Berk) and call it a day. The O2 sensor needs to be read correctly. If you have an 06+ you could disable the secondary O2 sensor with a Flashpro.
Originally Posted by playground_the
yor car need that o2 to run right, after your car is worm up and going into open loop, it needs both o2 to control fuel trim. with
Wrong. Only the primary sensor is at the header collector used for fuel trim. The secondary is just an O2 monitor smog snitch. I have the secondary o2 sensor disabled completely.
Old 09-16-2012, 08:12 PM
  #22
iDashX's Avatar
well i'm going to be purchasing a defouler soon and if you need one, lmk so i can pick up a 2nd one.
Old 09-16-2012, 10:08 PM
  #23
tkeyyy's Avatar
what's wrong with your t1r?
Old 09-16-2012, 10:29 PM
  #24
iDashX's Avatar
The T1R didn't work with my 70mm Berk HFC so I sold it. Then after dyno day, I found out I lost power so I just picked up a 70mm TP so now I need one.. I failed.
Old 09-16-2012, 10:33 PM
  #25
tkeyyy's Avatar
Originally Posted by tkeyyy' timestamp='1347862123' post='22016644
[quote name='iDashX' timestamp='1347855130' post='22016533']
[/quote]
i don't see what the point is of having a HFC.. it's 2x more expensive and they both don't pass smog. you can still smell something from it too
Old 09-16-2012, 10:36 PM
  #26
TougeHorseman's Avatar
Originally Posted by iDashX' timestamp='1347863379' post='22016661
[quote name='tkeyyy' timestamp='1347862123' post='22016644']
[/quote]
[/quote]
Mine don't smell, give it sniff!
Old 09-16-2012, 10:38 PM
  #27
iDashX's Avatar
[/quote]
[/quote]
can't smell anything from mines after everything is warmed up.
Old 09-16-2012, 11:14 PM
  #28
tkeyyy's Avatar
you guys both smoke though. i have a sensitive nose.
Old 09-16-2012, 11:24 PM
  #29
Does mine smell? I've never noticed, but perhaps others do?
Old 09-16-2012, 11:31 PM
  #30
tkeyyy's Avatar
Originally Posted by tkeyyy' timestamp='1347866045' post='22016705
[quote name='eklipz98' timestamp='1347863818' post='22016668']
[/quote]
Berk does have a smell.. i followed a friend and it wasn't as noticeable as a TP, but it's still there
Quick Reply: o2 sensor
