o2 sensor
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by LickyMYwalker' timestamp='1347810373' post='22015262
just use the BERK testpipe, it has a defouler built in. all you do is plug in your O2 sensor to the berk testpipe and it should work. new rule for smog is as long as you are OBD2 and no CEL, you pass smog ![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
![ponder2.gif](https://www.s2ki.com/forums/images/smilies/ponder2.gif)
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Originally Posted by eklipz98' timestamp='1347828033' post='22015721
[quote name='LickyMYwalker' timestamp='1347810373' post='22015262']
just use the BERK testpipe, it has a defouler built in. all you do is plug in your O2 sensor to the berk testpipe and it should work. new rule for smog is as long as you are OBD2 and no CEL, you pass smog![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
[/quote]
Of course, I can confirm. It takes one to know one
what kind of defouler? i remember i tried using hanzel's defouler and that sucker didn't work! it was from one of the DIY threads.
ended up buying a legit defouler and that one worked. it wasn't worth the headache and going back and forth to the store, so i invested about $15 for one.
I'm not using one at the moment, just have the o2 plugged into the CEL fix.....Even though my CEL turned back on.
Tomorrow i'll be trying out spark plug defoulers to space it out even farther. If that doesn't work then i guess im S.O.L and will have to deal with seeing it everyday. Haha
