California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
View Poll Results: what would be the next advisable upgrade?
stoptech sport brake kit with powerslot rotors
30.00%
cat back exhaust
70.00%
Voters: 10. You may not vote on this poll
next upgrade
Old 08-31-2012, 01:43 PM
  #41
madmaxblaster's Avatar
I am. I have been looking at the for sake section and just still deciding about which one I will be set to.
Old 08-31-2012, 05:26 PM
  #42
M-Type's Avatar
Where are you located? i have a HKS with stock cat on ap1 if you want a demo. Sometimes i see the HKS new go 'on sale' for like 700-800. little drone buts only at "slow" rpms haha
Old 08-31-2012, 05:39 PM
  #43
I live in san mateo. right beside hillsdale mall.
Old 08-31-2012, 05:48 PM
  #44
-BTT-'s Avatar
Originally Posted by XenonKiller99
Originally Posted by madmaxblaster' timestamp='1346288312' post='21974783
is there any stopping difference? i am not liking that the bbk cost so much just for the front kit. i wanted to upgrade the braking on all 4s.
Yes, there was very noticeable difference when Mac first installed them. I had to get used to the braking time and distance by lightly stepping on the brake pedal. It felt awkward and instant when braking at first but I've adapted. The OEM brakes are already very good but this makes it even better!
Keep in mind that a big brake kit won't stop you any faster. It's the friction between your tires and the ground that makes you stop, which also means that you need to balance the front and rear brakes properly, so good for you for considering upgrading all four corners. Otherwise, if you just upgrade the front, you could end up lengthening your stopping distances if your rear brakes aren't applying enough force relative to the front. Bigger brakes will change the braking feel and will dissipate heat better, but so will brake ducting, which is much cheaper.
Interesting article on balancing your brakes here: http://www.turnfast.com/tech_brakes/brakes_balancing
So my vote would be for ducting and more track days.
EDIT: One more article on regressive braking, a technique to significantly reduce heat without much performance loss: http://www.zpost.com/forums/showpost...7&postcount=27
Old 08-31-2012, 07:14 PM
  #45
Originally Posted by -BTT-
Originally Posted by XenonKiller99' timestamp='1346288649' post='21974795
[quote name='madmaxblaster' timestamp='1346288312' post='21974783']
[/quote]
Thanks for that info. Really good article from turnfast. Thanks for sharing. Learned a few more from that.
usafstud
08-13-2018 10:51 PM
jdmdohcpower
11-01-2017 03:31 AM
Fezzz
40
05-24-2013 06:39 PM
RichwiththeS2000
03-03-2011 01:33 PM
krazik
08-03-2001 09:41 AM
Quick Reply: next upgrade
